Full Version: Titan M O D ( last Updated 24-04-2019)
(2018-09-27, 09:08)Picard Wrote: [ -> ]I know it's been mentioned before in this forum, but I really miss Videolyrics PLUS, is there any way it can be used in Titan?
 what is that, replacement for script.cu.lrclyrics?
(2018-09-27, 03:58)t123thomas Wrote: [ -> ]Hi First thanks to all the developers of this mod, I have been using Marcel Titan skin for ages, as there is no further development from Marcel for kodi 18 as yet, hence, I resulted to using this mod which i found  fantastic. However, I have one major concern, mainly on the:
Skin settings >Homescreen layout>Horizontal Homescreen layout and titan tiles (1 row of large tiles) seems not be working, each time that I changed to either of the options, the screen will go black for a while then return to Netflix style.
here is the link to kodi log, hope it help to find and resolve the issue.
zixaloqabe (paste)
we know iot and dont 100% localice it, maybe its leia and xml are not up to date for dialog, or skinhelper, also its sometime random.
as i test on android . so, i think i will change , how to change home  layout in skin to avoid that in future.
here you go!
308626 (thread)
Is there a way to define the standard layout as something different in a config or xml file before you activate the mod, so that those that want to test with horizontal layouts could do that? Perphaps if the layout is already predefined it would be activate without crashing all of Kodi.
(2018-09-27, 13:42)Juppstein Wrote: [ -> ]Is there a way to define the standard layout as something different in a config or xml file before you activate the mod, so that those that want to test with horizontal layouts could do that? Perphaps if the layout is already predefined it would be activate without crashing all of Kodi.
As im on mobile,i cant test  if ever:thing is working.but it loads the homelayouts.
Go into userdata/addondata/skin.titan.mod.beta.leia
Open settings.xml with editor.
Look up for.
<setting id="homelayout" type=
PUT NOW YOUR WISHED HOMELAYOUT (string)
<setting id="homelayout" type="string">yourlayoutstring1</setting>
Tiles
3
1small
2small
3small
Vertical
simplever
simplever_tiles
verticalbig
Horizontal
simplehor
lowhorizontal
lowhorizontal_big
(Workin ones, as they dont have sublevel
Enhanced home = enhanced
Windows 10 = win10
Netflix 1 = netflix
Netfix 2 /bingie = netflix2)
save the file. And start kodi
Hi mardukl, from time to time two rectangles without content appear in the lower left corner in Netflix view. I believe to give a rating? Is there a way to disable them? I use Rpi 3, Libreelec Leia, Plexkodiconnect 2.4.1, Titan MOD 18.1.7
Thank you very much.
By the way, I love your skin!
(2018-09-27, 18:32)nilobar Wrote: [ -> ]Hi mardukl, from time to time two rectangles without content appear in the lower left corner in Netflix view. I believe to give a rating? Is there a way to disable them? I use Rpi 3, Libreelec Leia, Plexkodiconnect 2.4.1, Titan MOD 18.1.7
Yes.i forget about that.its the user rate addon.this should help
2769048 (post)
Hi mardukL, Thanks for this wonderful skin mod. I have been playing around with it and noticed some alignment problems on the homescreen using netflx bingie mode. The channel logo and rating for the shows, in this example "Blindspot" need to be raised slightly.
The problem is also the same for my movie widgets. The movie studio logo and ratings are half covered by the poster
Thanks again for all the great work to you and all involved!
(2018-09-27, 18:37)mardukL Wrote: [ -> ]
2769048 (post)
That solved the Problem, Thanks a lot.
As a little info.
For leia , the crash when switching homescreen is fixed.
But i havent time to put put out a new version in the next days.
So, you can download latest version here
https://github.com/marduklev/skin.titan....master.zip
I can confirm that. After you put all view options on the same level I was able to change to horizontal views by using your new fixed settings.xml
(2018-09-28, 14:58)mardukL Wrote: [ -> ]As a little info.
The is great I shall give a try later and report back
Hey buddy.. Thanks for the skin, glad you decided to do this Netflix version.. However, i have a problem. I use this skin on a personal build i use for my self, on Xbox there is an error in the skin helper service..
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.MemoryError'> Traceback (most recent call last): File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.skin.helper.service\service.py", line 10, in <module> from resources.lib.main_service import MainService File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.skin.helper.service\resources\lib\main_service.py", line 15, in <module> from webservice import WebService File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.skin.helper.service\resources\lib\webservice.py", line 11, in <module> import cherrypy File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.module.cherrypy\lib\cherrypy\__init__.py", line 76, in <module> from cherrypy import _cprequest File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.module.cherrypy\lib\cherrypy\_cprequest.py", line 10, in <module> from cherrypy import _cpreqbody, _cpconfig File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.module.cherrypy\lib\cherrypy\_cpreqbody.py", line 135, in <module> import cheroot.server File "U:\Users\UserMgr0\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalState\addons\script.module.cherrypy\lib\cheroot\server.py", line 1199, in <module> from ctypes import windll, WinError File "S:\Program Files\WindowsApps\XBMCFoundation.Kodi_17.99.131.70_x64__4n2hpmxwrvr6p\system\python\Lib\ctypes\__init__.py", line 556, in <module> _reset_cache() File "S:\Program Files\WindowsApps\XBMCFoundation.Kodi_17.99.131.70_x64__4n2hpmxwrvr6p\system\python\Lib\ctypes\__init__.py", line 276, in _reset_cache CFUNCTYPE(c_int)(lambda: None) MemoryError -->End of Python script error report<--
Now ofc as i said its for personal use so my log wont be "standard" like most people's,  Would you be able to assist in this,
Edit: 1.1.24 Skin helper service works perfect on Xbox One. but does not work with this properly,  i.e movie studio logo and ratings and the channel logo "blind spot" that's in a post above
(2018-09-28, 16:30)t123thomas Wrote: [ -> ]
I just download the zip file and refreshed the skin, this issue seems to have been resolved to far. I shall report any other issues occur.
Thanks again for the efforts
(2018-09-28, 15:31)Juppstein Wrote: [ -> ]I can confirm that. After you put all view options on the same level I was able to change to horizontal views by using your new fixed settings.xml
With that update its not necesarry to edit the settings xml anymore. 😉
Install it from zip or just copy the files from the main folder and overwrite if asked.
