2019-04-13, 05:30
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
2019-04-15, 06:58
(2019-04-01, 09:27)mardukL Wrote: [ -> ]Thanks but I think I haven't explained myself very well.(2019-04-01, 07:24)ferdinand Wrote: [ -> ]Is there a way to add custom tags for the skin to detect whether the file is a DVD and such?
I have these tags on multiple files: DVD, DVD5 and DVD9 and I want them to be shown as DVDs but the skin doesn't detect them and only shows the usual info. Is there a way I can add those tags?
You should be able to set smart playlist as widgets.
Just create an smart playlist with the kodi native editor
(videos -> playlists -> "new smart playlist" - which let you creat smart playlists ,which will be located in your userdata folder e.g. [ \userdata\playlists\video ]
Or do it manualy -> https://kodi.wiki/view/Smart_playlists
(but you need define the type - eg <smartplaylist type="movies"> or <smartplaylist type="tvshows">)
e.g.
xml:<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<name>my DVDs</name>
<rule field="tag" operator="contains">
<value>DVD</value>
</rule>
<order direction="ascending">random</order>
</smartplaylist>
I want Kodi to detect the tags I put in the filenames and show their source media logo. I just realize that Kodi/Titan doesn't shows logos for ISO files, is there a way to edit this? I'm talking about these tags and logos:
I have some files with a DVD tag but are ISOS (the same with Blu-ray tags and ISOS) and Kodi/Titan doesn't show logos for ISOS, I can change that?
Also I want to add custom tags and link them to their respective media type logo, like a WEBRip tag to be linke with the Itunes logo.
2019-04-18, 09:07
(2019-04-15, 06:58)ferdinand Wrote: [ -> ]i need to take a look at the variable used for that and the possibility.(2019-04-01, 09:27)mardukL Wrote: [ -> ]Thanks but I think I haven't explained myself very well.(2019-04-01, 07:24)ferdinand Wrote: [ -> ]Is there a way to add custom tags for the skin to detect whether the file is a DVD and such?
e.g.
<value>DVD</value>
</rule>
</smartplaylist>
2019-04-19, 08:31
(2019-04-18, 09:07)mardukL Wrote: [ -> ]i need to take a look at the variable used for that and the possibility.
Thank you, I will wait for your reply.
2019-04-19, 10:46
(2019-04-13, 05:30)t123thomas Wrote: [ -> ]Hi How doI get the game munu to show on MOD Titan skin, the menu shows in kodi default and Confluence skins.
game support is not fully done.sorry.
I cant say when i start 'game support'.
sorry
The additions /pr from here is merged into latest leia on git hub.
2019-04-24, 10:21
(2019-04-15, 06:58)ferdinand Wrote: [ -> ]I checked the variable today, looks fine to me.(2019-04-01, 09:27)mardukL Wrote: [ -> ]Thanks but I think I haven't explained myself very well.(2019-04-01, 07:24)ferdinand Wrote: [ -> ]Is there a way to add custom tags for the skin to detect whether the file is a DVD and such?
e.g.
<value>DVD</value>
</rule>
</smartplaylist>
If you have 'bluray' , 'blu-ray' , 'bdrip' or 'brrip' in your filename!, eg. - 'BATMAN_BDRIP.ISO' , 'batman(1968) - bdrip.mkv' you'll should have the BLURAY-flag-icon
xml:<value condition="[String.Contains(ListItem.Filename,bluray) | String.Contains(ListItem.Filename,blu-ray) | String.Contains(ListItem.Filename,bdrip) | String.Contains(ListItem.Filename,brrip)]">bluray</value>
IF YOU MISS any of the descripided naming conventions, it uses DVD as a fallback icon if your file is an *.ISO format
If you have 'dvd' in filename!, or SOME_MOVIE.ISO , or SOME_MOVIE.IFO , you'll will have the DVD-flag-icon
xml:<value condition="String.Contains(ListItem.Filename,dvd) | String.IsEqual(ListItem.FileExtension,iso) | String.IsEqual(ListItem.FileExtension,ifo)">dvd</value>
2019-04-24, 21:08
2019-04-25, 03:23
(2019-04-24, 10:21)mardukL Wrote: [ -> ](2019-04-15, 06:58)ferdinand Wrote: [ -> ]I checked the variable today, looks fine to me.(2019-04-01, 09:27)mardukL Wrote: [ -> ]You should be able to set smart playlist as widgets.Thanks but I think I haven't explained myself very well.
e.g.
<value>DVD</value>
</rule>
</smartplaylist>
Yep, thank you, I've already found the xml and edited it to add blu-ray and web-rip to be detected and it has been working great. The only thing that still isn't working for me is detecting the media source type from ISOs, in every ISO Kodi doesn't show a thing. I have one Blu-ray disc named "%Title% (%YEAR%) [Bluray].iso" and Kodi doesn't detect it as Blu-ray, I have one DVD disc named as "%TITLE% (%YEAR%) [DVD].iso" and again, Kodi doesn't detect it as DVD.
You can see that here:
I'm even using latest Kodi alpha.
It's something on my end then?
EDIT: So I have noticed that after playing the movie once, Kodi starts to show the blu-ray logo and also the codecs, for the codecs part I wasn't talking anything, I'm talking about the Blu-ray logo that now its appearing but only after playing the movie, it's there any way for Kodi to show the logo (to detect the source type) without needing to play the movie? It should detect it from the filename right?
2019-04-25, 11:18
Hi @mardukL
To thank you for your great work, and for the community, here is a link to a folder containing Color Themes and some screenshots.
These themes are focused on transparency with a reference color.
If you want to integrate them in Titan mod: it will be a great pleasure.
Thanks again.
Titan.mod.beta.leia ColorTheme
Thanks again.
2019-04-25, 11:27
2019-04-25, 11:33
(2019-04-25, 11:18)Aphykit2006 Wrote: [ -> ]Hi @mardukL
Thanks again.
i will add them, soon.
thanks.
since colors are finished, updated themes are welcomed :-)
2019-04-25, 11:47
(2019-04-25, 11:33)mardukL Wrote: [ -> ]With pleasure.(2019-04-25, 11:18)Aphykit2006 Wrote: [ -> ]Hi @mardukL
Thanks again.
thanks.
I just have a small display bug and some suggestions.
To listen to a radio certain information is not relevant or poorly framed: (see in yellow)
Album () genre == Radio name .
Regards
2019-04-25, 11:51
(2019-04-25, 11:03)Espartano Wrote: [ -> ]Hola , estoy un poco perdido en el foro, a ver si me podéis ayudar . Mi pregunta es : es conveniente actualizar al kodi más actual ? Afectaría a los addons ? Gracias y perdonad si no he escrito en el sitio adecuado
can you post again in english, pls!
may use google translate or any equivalent for that.
2019-04-25, 11:53
(2019-04-25, 11:47)Aphykit2006 Wrote: [ -> ](2019-04-25, 11:33)mardukL Wrote: [ -> ]With pleasure.(2019-04-25, 11:18)Aphykit2006 Wrote: [ -> ]Hi @mardukL
Thanks again.
thanks.
Regards
need to take look.
