Full Version: Titan M O D ( last Updated 24-04-2019)
I recently install this skin and started migrating my old setup to work with this - great work so far BTW!  I use widgets to display thumbnails of my media in each of my menu categories.  I'm not sure if this is skin related of if it's Kodi 18.2 that is the issue.  Under 17.6 the thumbnail images came across fairly quickly.  Now it seems to take quite a while for them to populate.  I could have sworn I saw someone mention a similar issue on here and the solution was to edit a certain file or something.  Any idea on how I could speed up the loading?  Is this a skin issue or Kodi itself?
(2019-05-17, 16:54)nabsltd Wrote: [ -> ]
(2019-05-17, 14:46)mardukL Wrote: [ -> ]ok, i will respect this and will add it as new viewtype :-) So panel low (521) will be
spared ...
Thanks. Since it's working fine now, and has been for a while, hopefully it can just be ignored and it will keep on trucking, so it won't add to your support work.
Its changed now on git/for next release
- panel low (521) is back
- circle (528) is new viewtype
No ETA , as i dint have much time atm.
(2019-05-22, 11:54)Hokage1804 Wrote: [ -> ]Hi guys, I'd like my house to look exactly like this
What are the steps, addons, or other files that you use to get the same thing
I use kodi 18.2, TITAN MOD with an Imac
Again, the puc is showing the spotlight widgrt on focus (if its populated you csn focus it when click up from first widget row) you need library content(movie/show), no addon.
(2019-05-22, 18:39)moonchilddave Wrote: [ -> ]I recently install this skin and started migrating my old setup to work with this - great work so far BTW!  I use widgets to display thumbnails of my media in each of my menu categories.  I'm not sure if this is skin related of if it's Kodi 18.2 that is the issue.  Under 17.6 the thumbnail images came across fairly quickly.  Now it seems to take quite a while for them to populate.  I could have sworn I saw someone mention a similar issue on here and the solution was to edit a certain file or something.  Any idea on how I could speed up the loading?  Is this a skin issue or Kodi itself?
- i am just aware that skinhelper service widget takes a huge amount of time for loading sometimes, i recommend avoid that widgets
- in the widget setting (skin and addon)
you can set the value for widget items to be shown (i recommemd '25' for skinhelper widgets)
Why I have this empty place between the icons. Is this meant to be or is there something wrong ?
See the image below. Thank you !
https://imgur.com/a/ZI6qJeE
Sorry, here is image...Thank you!
(2019-05-31, 08:44)simtaj Wrote: [ -> ]https://imgur.com/a/ZI6qJeE
Known "bug" in the control for mediaflags.
Still on to do list.
(2019-05-31, 12:05)mardukL Wrote: [ -> ]
I think I solve it some while ago, check my flags xml. Also there's an issue with language packages they need to use three chars to work now but most are two chars pngs.
Can I suggest a minor fix. In Netflix 523 skin - under title when Clearlogo isn't visible, for Conditional Visibility for TVshows you should use the field: $INFO[ListItem.TVShowTitle] - and for all others $INFO[ListItem.Title] (as you currently do).
Some addons only use the TVShowTitle field - and so if you only use Title then TV shows don't show the title when a Clear Logo isn't available
Is there a way to remove the logo clear-art form the OSD?
https://imgur.com/a/tpRKYcg
(2019-05-30, 12:01)mardukL Wrote: [ -> ]
THANK YOU.
(2019-06-03, 03:17)raujaku Wrote: [ -> ]Is there a way to remove the logo clear-art form the OSD?
intended placement, sorry.
upps.misread, i will add option to en/disable.
Maybe some little tweeks at a later stage ,mabe 4rd osd layout.but not very soon.
rare time for skinning atm.
just some improvements and fixes on to do list for next release.
Hopefully finished soon.
If everything goes well, update will be ready next week,
- changed spotligtht widget behaviour for Netflix Home , its no longer on top row (if you dont want it there ;-)) , its an own widget layout now
- use it or not
- use it for whatever content you want
- use it wherever you want it to be (like every other widget)
Still in early progress,but not much left to do...
https://streamable.com/wlvgh
MardukL, question. Any way to password protect a home menu item?
(2019-06-06, 07:14)jdig4240 Wrote: [ -> ]MardukL, question. Any way to password protect a home menu item?
Actual no,sorry.
Unsure if i will add it some time.
