(2019-11-21, 10:07)simtaj Wrote: [ -> ] (2019-11-21, 06:11)mombasa123 Wrote: [ -> ]@mardukl
Couple of things with the latest update if you could look at perhaps pls?
1) The plot text in Netflix views is too large - a bit unsightly. Preferred the previous font size as can get more in without scrolling. It doesn't look good on my 65' TV. I saw your reply to another post sating its hardcoded now but any chance of making it smaller please?
2) The borders on Movie posters in NetFlix views is now white and thicker? I preferred the previous red border and found a way to change in Custom Colour menu. Any way of making the border a bit thinner like in previous version of the skin?
Cheers
I agree too, on my 65inch tv the plot fonts are really too big.
And fonts under widget youtube subscriptions (circle layout) they are even bigger and bolder. They look really too much on big screen.
Are you using default or optional (helvetica font, can be choosen inartwork settings)
Here is what i pushed to git - reg28
or you can test by edit : Includes_fonts.xml , line 89, Reg28 to Reg25
xml:
<include name="font_Plot">
<font>Reg28</font>
</include>
https://github.com/marduklev/skin.titan....7466bc4502
to get ...
(2019-11-21, 10:35)mardukL Wrote: [ -> ] (2019-11-21, 10:07)simtaj Wrote: [ -> ] (2019-11-21, 06:11)mombasa123 Wrote: [ -> ]@mardukl
Cheers
Where can I find this setting?
(2019-11-21, 10:26)simtaj Wrote: [ -> ] (2019-11-21, 10:24)mardukL Wrote: [ -> ] (2019-11-20, 19:30)simtaj Wrote: [ -> ]Sorry, I can’t find shorcut settings. In configure shortcut there is no show tags option.
fixed on git
https://github.com/marduklev/skin.titan....b81a8bcff0
- respect widget setting (en/disable tags)
dont forget somoptions ;-)
- alignment working
- colors working
Thank you, will try today.
I tried. Tags are working, thank you. But now with poster layout I can’t see all fonts.
(2019-11-21, 10:44)simtaj Wrote: [ -> ] (2019-11-21, 10:35)mardukL Wrote: [ -> ] (2019-11-21, 10:07)simtaj Wrote: [ -> ]I agree too, on my 65inch tv the plot fonts are really too big.
Settings -> media liibrary settings - in artwork section, last setting
i pushed a change to the default (non helvetica size)
xml:
<font>Reg28</font>
</include>
to get ...
Cheers
xml:
<font>Reg28</font>
</include>
to get ...
On Circle layout I don’t think I can change font. They are changing only on landscape or poster layout widgets.
(2019-11-21, 10:56)mardukL Wrote: [ -> ] (2019-11-21, 10:44)simtaj Wrote: [ -> ] (2019-11-21, 10:35)mardukL Wrote: [ -> ]Are you using default or optional (helvetica font, can be choosen inartwork settings)
xml:
<font>Reg28</font>
</include>
to get ...
In Media library views-artwork settings the last option is: Use Netflix FontStyle...
And if I check or uncheck this setting fonts are the same.
(2019-11-21, 04:55)t123thomas Wrote: [ -> ]Hi I found another bug episode #'s are missing or let me know if I am missing a settings
As it is a bit special here (no tags between 2 rows), i like to have an overlay like that.
Other Layouts can use toggle tags, for that case.
I dont like to have an big overlay on thumbs.
pushed on git -
https://github.com/marduklev/skin.titan....0e40a8e135
in case of spare time, pushed some fixes with new version.
(update possible via KODI itself)
C H A N G E L O G (v13+14)
Quote:## version 18.1.14. - 21.11.2019
- add widget header textcolors to 'set color string' on first load
- add posibility to en/disable tags on netlix home
- add overlay for episode thumbs (view525)
- slightly smaller font default plot netflix views
- fix toggle botton (selected condition)
## version 18.1.13. - 17.11.2019
SETTINGS WINDOW
- changed layout
- removed some needless settings,removed depreciated/broken addons support (incl. artwork downloader)
FOOTER
- Clearlogo (if used in footer) always centered
- adjusted rating images
- recode
SKINSETTINGS
- removed :
- dont show clear logo netflix home
- dont show plot for unwatched/in-progress episodes
- removed dontshowfooterbar on home
- toogle each ratings seperate (imdb,top250,rottencritics,rottrenaudience,metacritic,tvdb,themoviedb),
* Skinhelper no longer needed, make use of scraped/nfo ratings
* fixed wrong rating variable (recode footer)
* make use of skinhelper just if wanted as fallback if scraped ratings missing (using simplecache)
- added new custom color -> widget header color (was needed to keep details color and widget header color different)
- use optional helveticaneue font for netflixlayouts (doesnt support cyrillic),
- en/disable option in artwork setting-section
- moved Skin.HasSetting(Home_TransParentTiles) setting to corresponding home section
- Trailers will auto fallback to youtube, if not "never do online lookup" is enebled (WIP)
- add new color ' ViewListAndDetailPanelColorNF '
- intention - diffused color for non-/-focused items, without losing wished colors in other layouts -
- choose if you wann use skinhelper service or native(Non-Addon) for showing ExtraFanart
- when not using skinhelper, you will also have rotating fanart available for musicvideos
- CHOOSE CAST PROVIDER for VideoInfo
- or skinhelper service
- or embuary
- added CAST ACTION
- perform library search via Skin Search by selceting a cast member in VideoInfo (actual just non netflix videoinfo)
- add new setting to use new "enhanced VideoInfo Screen" https://streamable.com/r969u
( it uses - 3 scrollable 'pages' (options for toggle some unwanted containers show/dont show will come next update) )
- Netflix2 Home - decide between 2 spotlight button layouts (frame bg, panel bg)
- check your Colors in Custom Color Section because they are need to handle colors differently
- Netflix Layouts - choose between Mpaa 2 Flag Layouts (default = diffuse frame , Alternative Layout = panel bg (Netflix Style))
EXTENDED INFO
- fixed studio logo not showing
FONT specific
- add new font helvetica neue for netflix layouts https://imgur.com/a/44UVJQo#xEHxgmp
HOME
- solved issues with "dont showing Widget Header" when scroll up again
- Win10 - enebled option to use zoom animation
- win10 - fixed scrollbar, now could be focused
- added option - show widget header centered
- larger square submenu , removed outstanding label, add submenu label at item bottom (optional layouts WIP)
HEADER
- slightly decreased height and adjusted labels/icons (comparison def vs. win10 style https://i.imgur.com/FfLnn2h.jpg)
(there will a decision , to just use 1 header header layout in future)
- add label/content for skin search
WIDGETS
- widget header are no longer hidden, when scroll up to previous widgets (all vertical home layouts)
- fixed several issues , when using multiple rows for some layout types
- cleanup some conditions
- landscapewidebox - slight edit of focus animation
- is always fixed-list now
- added option to use use "dimmed play button" on focus
- changed focus zoom for widgets
- add focus animation for detail widgets (posterdetails,landscapedetails) (always)
- removed tag OVERLAY, tags are now at bottom below widget, not inside artowrk
- added new widget type 'circle' https://streamable.com/jwzqt
- added new widget type 'netflix spotlight' , replacement for current spotlight WIP, improvements needed
- correction posterthumb position - posterdetails widget
VIEWS
- fixed issue where No/wrong viewtype label is shown (525,526,527)
- fixed color issues
- added option to use use "dimmed play button" on focus (Credits for the Idea and the the playbutton belongs to @SualFred)
- add NEW viewtype 'Circle' kept the id (529)
https://imgur.com/a/q4ZkfOq
- Panel Wall (520)
- dont show header ( fixed overlay )
- List (50)
- removed discart option
- Netflix Potser - View (523)
- fixed discart animations
- fixed artwork + focusedlayout position
- optional font style for Titles if clearlogo not available (https://i.imgur.com/asXO5CQ.jpg)
- adjusted layouts in generell
- Netflix Potser - View (525)
- improved layouts in generell
- Adjustments for PVR layouts (Thanks to @Fuchs2468)
TAGS
adjusted view types to use tags at bottom instead overlay (WIP, sizing)
overlay based on missing artwork is still in
- toggle them on off via Slidemenu Setting in Viewtypes, or in Shortcut Section for Widgets
SHORTCUTS
- fix some paths to windows
- fix not working submenu for "Music" Entry
- fix not working subsection for Shows: recentlyaddedepisodes, inprogresstvshows
- add some default Submenu entry for "TV Shows", "Musicvideos", "Movies"
- use xsp/native path (just) for sub sections instead skinhelper.service.widgets for : recentlyaddedmovies , InProgressMovies, UnwatchedMovies
SEARCH
- adjusted custom search (spotlight bg image unresolved)
MISC
- fixed animated art behaviour, removed skinhelper as source, use native
(may require refresh of movie ,need set art for movies ['animatedposter' 'animatedfanart' in advancedsettings.xml], need kyradb api/user key to use it with artwork beef)
- REMOVED THEME 'CLASSIC' completly
- come small fixes/resolve kodi log errors, and performance improvements
- removed 'resource addon check' on first settings visit -> set them manualy if wished
- some more minor stuff and fixes, to improve performance
- cast provider on Netflix Trailer Playback in is now 'embuary helper' , faster (also dont need predefined actions actions)
- alphabet scrollbar 'provider' is now embuaryhelper, seems faster, also hiding 'empty' letter content
(2019-11-21, 11:34)mardukL Wrote: [ -> ]in case of spare time, pushed some fixes with new version.
SETTINGS WINDOW
- changed layout
FOOTER
- recode
SKINSETTINGS
- removed :
- or embuary
- added CAST ACTION
EXTENDED INFO
FONT specific
HOME
HEADER
WIDGETS
VIEWS
- Panel Wall (520)
- List (50)
TAGS
SHORTCUTS
SEARCH
MISC
No matter what I choose, I can’t see all fonts on screen under widgets.
(2019-11-21, 12:07)simtaj Wrote: [ -> ]
No matter what I choose, I can’t see all fonts on screen.
if you're not refer to the tags , i dont get you.
did you refer to widget taglines ?
(2019-11-21, 12:18)mardukL Wrote: [ -> ] (2019-11-21, 12:07)simtaj Wrote: [ -> ]
You see picture. Text under widget (episode name) is not visible on screen. You can see it only half of text.
(2019-11-21, 11:12)simtaj Wrote: [ -> ] (2019-11-21, 10:56)mardukL Wrote: [ -> ] (2019-11-21, 10:44)simtaj Wrote: [ -> ]
Aye, I can't see Default Font setting either - only Use Netflix FontStyle which does not seem to do anything
mardukL
Happy to recieve updates to my most loved and favorite skin. Thanks for that...
All said and done, but the version number at bottom right of the settings screen is still old, please check.
Keep up the good work...
Hello @
mardukL . You were a little faster with your official update than me with mine for you.
I have made some changes to the OSD display. It was a little more work than I thought.
- positioning reworks better readability even with long texts
and all texts again within the OSD area
- color gradient now works everywhere (slim-osd and default-osd)
- change of channel pvr now again via osd up and down possible
- "Ends at" and "duration" now available on every OSD display
- missing pause ad added to some osd ads
- clearart now available everywhere
- netflix-OSD without osd-info "title display" added and clearlogo at PVR
- netflix-orgin episode title display changed (logic error always shows "Next Episode" no matter which one).
Episode title is now more readable even with longer texts
(mardukL please look again here if the color change was necessary from me have exchanged primarily with secondary color)
- vertical-osd panel background size adjusted now also fits into the display
I hope I did not forget anything.
Everything changes work very well for me, tested with Win10 and Libereelec (Raspberry Pi 3+).
Here the files for download:
1080i_xml_update_21_11_19.zip
Your update from today is considered.
