2018-04-13, 15:39
Hello!
When watching Live TV, is it possible to stop the playback when going back to the Live TV menu, instead of the video playing on the background?
I have seen suggestions to install the Keymap add-on and map the BACK button to also trigger a STOP action. I don't know whether that works only when using a remote but in any case, I believe this is not a solution, because then it won't be possible for example to open the EPG just to check something and then press BACK to return to the playing channel - that will stop the channel, right?
I've seen this implemented in the skin "Nebula" - it can be enabled in Settings > Skins > Play > Stop playback on return to menu
However, that doesn't seem possible in the default skin (Estuary), and I would prefer using it. So, is it possible to do in Estuary? Or is there any add-on that can do what I want?
P.S. I'm not sure whether I've picked the correct sub-forum to post this. If it is not, I beg a friendly moderator to move it.
