Full Version: tunir - radio plugin
I'm looking for good radio plugin.
Most stations I want to have (polish, rather traditional ones transmitted through the web than millions of web stations) I' ve found working in Tunir.
I can group them into My stations list (there are few lists in the addon, I want to use this one only).
And.... is it possible to add this particular list to menu as Radio?
My target is to setup remote and LCD display to start and navigate through radiostations without using tv, so it must be easy to run.
Suggestion of other addon which can do it is also good answer Smile
Hi there!
I'm also looking for a good radio plugin! one that can work with kore and is easy to manage and where I can create a list of favorite radio I can easely access.
Thanks for the help
Laurent
