Full Version: Picture Freezes at Ends of Clips (Hardware Acceleration)
I'm having issues with picture freezing during the last second or two of most/all videos (audio keeps playing just fine).
Turning off "Allow Hardware Acceleration - amcodec" fixes the issue, at the expense of degraded image quality and glitch-y playback in general.
Debug log here: http://pastebin.com/Eydu1Szc
Any pointers here much appreciated!
Kodi 17.6
LibreELEC 8.2.4
WeTek Hub (aarch64)
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Added debug log to original post (also here: http://pastebin.com/Eydu1Szc).
Many thanks again for any assistance!
Huge thanks for any help here. Maybe someone could point me to the team/community that works w/ hardware acceleration via amcodec? Cheers all.
You can also try the LibreELEC forum. Which specific AArch64 device is this about?
Hey thank you! Not sure how I missed your reply when it posted. I'm using a WeTek Hub.
