Full Version: wakeup with usb remote
Hi, this is my first test of xbmc for linux, I have been running the xbox version sins the start of the project.
I have to start by giving every body involved with the project a big “thank you!”
Im running this on a HP dc5700 1800 core 2 duo, 1GB of ram and a MCE remote
Every thing works fine including HD movies in 1080p x264
But there is one thing I need som help with and that’s wake up after sleep using the USB remote.
When the the computer is sleeping the ir-indicator diode doest indicate anything.
If I remove the usb ir-receiver and reinsert it the computer wakes up.
WOL and keebord wakeup is working fin.
/johan
I got sleep working now, it was a bios issue.
But when it restores from sleep the remote stops working until I restart xbmc
Is there a way to reinitiate the remote function I xbmc?
If you'd bothered to search there is an entire thread addressing this issue.
And it's fixed in svn now! thank joad for all the testing Smile
