Full Version: Kore artwork issues with 1 of 2 instances (MySQL)
Hello,
Kore does not display any artwork when connected my x86 device, which runs LibreELEC. This devices shares the same database, via MySQL, with a Raspberry Pi, also running LibreELEC. Same versions. When connected to the Pi, artworks shows up in Kore. Is there a debug option or a log I can check for this type of issue? Any help is appreciated.
The artwork is fetched from your x86 device through HTTP. Is it possible that the port you used is being blocked in your network?
Take a look at this to see what's the address: https://kodi.wiki/view/webserver#Image_cache_.2Fimage
