Full Version: Will kodi 18 support surround sound 9.1?
As the question in the topic says... Will kodi 18 feature the option of running 9.1 surround sound? At the moment you can only go up to 7.1. Also i was wondering on weather anyone knew which setting I can currently use for my 9.1 system? I'm guessing it won't work on either 5.1 or 7.1 ?
Wouldn't it be better to use passthru in this case?  Then Kodi doesn't need to worry about the channel format at all
