also, would it be possible to add plots to the widgets of episodes?Thanks in advance.
Great skin. Thanks a lot.
Question: in the plot (when pressing pause) the name of the movie or tvshow doesn't show up. It says " Not available"
This is what I mean:
https://imgur.com/a/T894bso ("Niet beschikbaar")
That's what I get with every movie or TV show. I play only local files.
I'm on Leia.
Btw: It does only happen when you press on pause. Not when you press on the "I" button. When you press on "I" then you get all the information.
It also happens on Krypton. I have all the required add-ons installed, like script.skinshortcuts etc.. When pressing on pause the name of the movie or tvshow doesn't show up in the plot.
I tried it on Windows and Mac, both the same issue. Can you please fix this?
Thanks in advance.
It should be fixed in the latest revision on Github.
Tgx
(2018-05-05, 18:55)Tgxcorporation Wrote: [ -> ]It should be fixed in the latest revision on Github.
Tgx
Yes it is! Thanks a lot
Hello,
Really nice job with the skin, i like it a lot.
Since i activated pvr iptv simple client the widget shows icons of the tv guide and not the logo's of the channels like estuary so its not really beatiful. Can i fix this ?
Thank you.
I cannot find your fantastic skin in Kodi 18 RC1. Will there be a version in the future?
Greetings
This is an amazing skin! Will you update skin to work with rc2 relase, please? Thank you!
I love Andromeda and am doing all I can to push its customisability to the limits. If the dev/s want help or feedback, please get in touch.
I believe it is not compatibile with RC5 although I think RC5 is very new and it must be hard to keep up. I was hoping the dev/s could give us an update on here when it keeps up with each pre-release release, and I'll refrain from updating Kodi again until I'm told.
Sam.
I’m going to post an update for the final Leia version
Tgx
Do you advanced skinner types get any info on when that might be? Using Estuary while I wait is killing me. Andromeda is that much better. I might try to get an RC4 version from somewhere.
The version on Github is working fine with the latest Kodi Leia
Tgx
