Full Version: Kodi Laia 18 -> New builds are bugging the File view
Hello Gade,
since the last 3 Nightlys the File Mode in view "List" is bugged.
There are no files visible. BUT i can move in this files.
I'll make a short video to make it clear.
https://youtu.be/GJuKV8e1ZU4
Hi skybird.
Thanks for reporting.
There's most likely nothing I can do on the skin with this.
It's probably introduced with this PR: https://github.com/xbmc/xbmc/pull/13754
I haven't had the time to go into the debate yet: https://forum.kodi.tv/showthread.php?tid=330696
A lot of views is not working properly after that PR.
:/ i don't thing they will undo this pr. estuary was changed to work properly with this changes.
I don't see at all why the PR should be undone?
Bugs, the PR has introduced, are fixed as they show up - with new PR's.
Nothing has been changed in Estuary.
I'm currently in the middle of moving from one place to another, so I don't have time to look into this.
It could have something to do with skin strings or window properties, but I can't be sure before testing myself.
Hello Gade Smile Do you had time to take a look for this issue with new laia builds? (build from 14.04.18 works, new not)
Hi skybird.
You bet!
I found the reason for this and I'm hopingĀ @ksooo can fix it:
https://forum.kodi.tv/showthread.php?tid...pid2740026
If it's not able to be solved in Kodi master, I have another solution ready. But this would require a huge amount of code work.
Angelinas got me on the right track and all issues related to this is now fixed with this commit: https://github.com/gade01/Rapier/commit/...0af7c67e5c
I have pushed a development version to my repo and will mark this thread as solved.
