Full Version: Casa de Papel Part 2 - netflix
Pages: 1 2 3
Hello Everyone,
I've download the part 2 (or season 2) for the tv show "la casa de papel" or "money heist" but kodi doesn't recognise some of my episods (E15 -> end).
It only know the spanish cut : season 1 - E01 -> E15 while in Netflix it s Season 01 E01 -> E13 and season 2 E1 -> E09 (and it's what I have)
Do you know how I can add my episods ?
Thank you very much
I hope it's understandable, I'm french ^^
Easy understandable version :
La casa de papel : 2 version : spanish tv and netflix.
Spanish tv =  season 1 - E01 -> E15
Netflix =  Season 01 E01 -> E13 and season 2 E1 -> E09
I have the Netflix version but Kodi only recognise the spanish cut.
Hope it's better ^^
thetvdb.com only has season 1 on it you should use a different scraper imdb has both seasons
Thanks for your reply but I don't have IMDB on the extension list.
I've tried with wem and the movie database but still don't work :/
Universal_Movie_Scraper (wiki) uses imdb
you will have to add it to thetvdb or create .NFO files
I can use it only for movies, not tv show. If I add the th show "casa de papel" in movies and use universal movie scraper on it, it find some strange movies
The Universal Movie Scraper can only be used for Movies, not TV Shows
@overhead
You need to check the listing at TVDB. There is no Season 2 listed... https://www.thetvdb.com/index.php?tab=se...417&lid=16
Your options are:
1. Create an account at TVDB and create the new episodes (preferred)
2. Create NFO Files.
For future reference, missing metadata is not a Kodi issue, but an issue for the scraper site.
Probably worth reading the discussion here, https://www.themoviedb.org/tv/71446-la-c...62a2036043
thank you, so there is no solution :/
sorry for this post and thank again
Yes, use .nfo files.
seems realy complicated...
I will do without
Je t'ai fait un pack avec mes nfo crées pour faire les 2 saisons comme la diffusion de netflix si tu veut.
https://mega.nz/#!GIEiVSDT!HTrWUQVjzqKws...BqojkNhL_U
Merci !
Il y a deux diffusions du coup, une diffusion de 2 saisons sur Netflix et une en une seule saison ?
C'est ça?
La diffusion d'origine en espagne était en une seule saison de 15 épisodes de 70min, netflix là redécoupé pour une diffusion plus conventionnel en 2 saisons de 45min ( 13 et 9 épisodes ).
cest ce que je pensais !
Tes NFO marchent bien par contre, sur la saison 2, "Episode" est retranscrit "pisode"
cest le E majuscule accent aigu qui pose probleme, est ce que tu peux remplacer les E majuscule accent aigu en E sans accent ?
En effet et c'etait pareil pour les résumés, ça doit etre mieux là : https://mega.nz/#!GIEiVSDT!HTrWUQVjzqKws...BqojkNhL_U
Pages: 1 2 3
