Full Version: TV Guide Runtime
Hi @Gade
In the TV Guide listing, the Runtime is out by a few minutes Wink All 7 entries on that page are incorrect.
Is this something you can look at, or is it an add-on issue like the Ratings of a few months ago?
I am using v10.5.15 on Win10 Kodi v17.6. TV Show- Next Aired v7.0.1
Hi Karellen.
Thanks a lot for reporting.
That's probably an addon issue.
I bet all your issues will be fixed if you use the official version: 6.0.15.
Thanks @Gade, I'll downgrade and report back Smile
Yes, installing v6.0.15 fixed the Runtime issue. Also displays tv show posters.
Thanks Smile
No problem. Smile
Thread marked solved.
