Full Version: Allow Action ChapterOrBigStepBack to seek before chapter 1
ChapterOrBigStepBack works on VideoPlayer Seek method. The current logic looks if chapters are present in the video and if so, will seek back to previous chapters until chapter 1 is reached. At this point an attempt to send ChapterOrBigStepBack fails because it won't allow seek to chapter 0. If Chapter 1 is not at the beginning of the media, you have to seek back until the play point is prior to the chapter 1 time, after which the "bigstepback" logic works.
I propose a change to the logic of Seek, so if the playing media has chapters and ChapterOrBigStepBack attempts to seek back to Chapter 0 (so GetChapter() = 1), that instead of doing a SeekChapter the logic instead finds the appropriate SeekTarget from the Chapter 1 time (either -10:00 or start of media).
The method change appears to be in VideoPlayer.cpp
void CVideoPlayer::Seek(bool bPlus, bool bLargeStep, bool bChapterOverride)
scott s.
(2018-04-19, 23:50)scott967 Wrote: [ -> ]ChapterOrBigStepBack works on VideoPlayer Seek method. The current logic looks if chapters are present in the video and if so, will seek back to previous chapters until chapter 1 is reached. At this point an attempt to send ChapterOrBigStepBack fails because it won't allow seek to chapter 0. If Chapter 1 is not at the beginning of the media, you have to seek back until the play point is prior to the chapter 1 time, after which the "bigstepback" logic works.
scott s.
is on my list for removal. player API supports SeekChapter and SeekTime. your request may better fit into SeekHandler
