Full Version: Problem with Kodi and DigiOne Allo
Hello,
I have a DigiOne Allo and I'd like to try with Kodi for my Raspberry pi3+.
I installed Raspbian desktop and Kodi 17.6.
The problem is that in the audio preferences I can choose only snd_digione_all analog and not SPDIF
this is what I get from aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndallodigione [snd_allo_digione], device 0: Allo DigiOne HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
any help, please?
P.S. I tested also LibreElec 8.2.5 and the DigiOne Allo Spdif is recognized but the AC3 passthrough is broken
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
@nickr
Thanks for your reply and assistance
This is my debug log
http://paste.kodi.tv/kihovawija
Look at this thread on the LibreELEC forum: https://forum.libreelec.tv/thread/12047-allo-digione/
In order to get a SPDIF output device you need an ALSA card conf. We added that to LibreELEC 8.2.5 so passthrough should work there.
so long,
Hias
Here is the alsa.conf, if it works with Libreelec it should work in Raspbian:
https://github.com/LibreELEC/LibreELEC.t...giOne.conf
It works with LibreElec but only DTS is recognized...AC3 gives a terrible noise!!!
Quote:Here is the alsa.conf, if it works with Libreelec it should work in Raspbian:
Quote:https://github.com/LibreELEC/LibreELEC.t...giOne.conf
Where should I put the AlloDigiOne.conf in Kodi (under Raspbian)?
(2018-04-20, 15:58)calabuig1969 Wrote: [ -> ]Where should I put the AlloDigiOne.conf in Kodi (under Raspbian)?
/usr/share/alsa/cards/
so long,
Hias
(2018-04-20, 16:06)HiassofT Wrote: [ -> ]
so long,
Hias
I put it in /usr/share/alsa/cards/ of root directory...not under a kody folder. Is it rght?
No change in Kodi.
Yes, that's right. Did you enabled the dtoverlay for that board ? See post #4 and #5 from the Libreelec forum above.
Also you seem to be using berryboot which ships with it's own kernel, that might be a problem.
Ok, it works, I can choose DigiOne SPDIF passthrough, but while DTS is ok, AC3 is broken, a terrible noise from my speakers!!!
Here's my debug log:
http://paste.kodi.tv/eluxohepom
