2018-04-21, 16:40
OS: Fedora 28
Kodi: 17.6
On a fresh OS installation, Kodi is terminated (SIGABRT) right after displaying the splash screen with the following error message:
-> Kodi crash log
The mentioned call to abort() happens in Thread 1, inside CGUIFontTTFGL::LastEnd():
Kodi: 17.6
/usr/include/c++/8/bits/stl_vector.h:932: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::operator(std::vector<_Tp, _Alloc>::size_type) [with _Tp = SVertex; _Alloc = std::allocator<SVertex>; std::vector<_Tp, _Alloc>::reference = SVertex&; std::vector<_Tp, _Alloc>::size_type = long unsigned int]: Assertion '__builtin_expect(__n < this->size(), true)' failed.
/usr/bin/kodi: line 175: 7640 Aborted (core dumped) "$LIBDIR/${bin_name}/${bin_name}.bin" $SAVED_ARGS
-> Kodi crash log
gdb:Thread 1 (Thread 0x7f3d3298d500 (LWP 6885)):
#0 0x00007f3d287f9f4b in raise () from /lib64/libc.so.6
#1 0x00007f3d287e4591 in abort () from /lib64/libc.so.6
#2 0x0000561020d9a485 in CGUIFontTTFGL::LastEnd() ()
#3 0x0000561020deead1 in CGUITextLayout::Render(float, float, float, unsigned int, unsigned int, unsigned int, float, bool) ()
#4 0x0000561020da03f7 in CGUIControl::DoRender() ()
#5 0x0000561020db0355 in CGUIControlGroupList::Render() ()
#6 0x0000561020da03f7 in CGUIControl::DoRender() ()
#7 0x0000561020db0355 in CGUIControlGroupList::Render() ()
#8 0x0000561020da03f7 in CGUIControl::DoRender() ()
#9 0x0000561020dad41e in CGUIControlGroup::Render() ()
#10 0x0000561020da03f7 in CGUIControl::DoRender() ()
#11 0x0000561020dad41e in CGUIControlGroup::Render() ()
#12 0x0000561020da03f7 in CGUIControl::DoRender() ()
#13 0x0000561020dad41e in CGUIControlGroup::Render() ()
#14 0x0000561020da03f7 in CGUIControl::DoRender() ()
#15 0x0000561020dad41e in CGUIControlGroup::Render() ()
#16 0x0000561020da03f7 in CGUIControl::DoRender() ()
#17 0x0000561020dad41e in CGUIControlGroup::Render() ()
#18 0x0000561020da03f7 in CGUIControl::DoRender() ()
#19 0x0000561020d7d018 in CGUIWindow::DoRender() ()
#20 0x0000561020d82e48 in CGUIWindowManager::RenderPass() const ()
#21 0x0000561020d8302f in CGUIWindowManager::Render() ()
#22 0x0000561021349eed in CApplication::Render() ()
#23 0x00005610213f2d45 in CXBApplicationEx::Run(CFileItemList&) ()
#24 0x00005610211451a0 in XBMC_Run ()
#25 0x0000561020c39fa9 in main ()
