I have a slight problem in changing channel audio to Portuguese Made a channel change it returns to English as default. In summary the change of the audio has to be made whenever channel change.
this is a Kodi/add-n issue
Thank you for the reply, gentlemen.
CoreELEC KI Pro, Kodi 18.0 ALPHA2.
Brazil
erbas You already posted this in the CoreElec thread and were advised that this has nothing to do with any specific ROMs.
(2018-04-24, 02:43)HeresJohnny Wrote: [ -> ]@erbas You already posted this in the CoreElec thread and were advised that this has nothing to do with any specific ROMs.
Hi friend, I was told it was kodi's problem!
Or am I in the wrong forum?
What you mean by that is specific and direct!
What I'm Looking For And Help!
You are posting the LibreELEC test-thread.
CoreELEC is not LibreELEC. It's not that it is 'completely different' from a user POV. But it somehow is from a developer POV. 'If' your problem is a Kodi problem, I would suggest posting this at the general Linux sub-section (where I will split that posting to after writing this posting).
If it's a specific problem with a specific add-on. I would also suggest to, at least, mention the add-on you are using and providing a full
Debug Log.
