When opening any AddOn in Kodi I get the message VistaTVAuthSystem Enter code. I have to click Cancel many times before I can get into the addon. I think this is a Virus. How do I get rid of this annoyance.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
