2018-11-11, 20:10
2018-12-05, 08:40
Hi Nonjon,
is there a reason why Quartz seems to have disappeared from the official repository?
I'll come with proper feedback on music section soon, I hope. The home situation hasn't allowed me to give this proper attention unfortunately.
2018-12-05, 10:54
(2018-12-05, 08:40)mediumdry Wrote: [ -> ]is there a reason why Quartz seems to have disappeared from the official repository?
Not just quartz. Looks like about 10 skins have vanished since RC1. Thanks for the heads up.
Edit: This explains it. I submitted the update for v5.4.4. Should reappear soon.
2018-12-07, 23:11
Version 5.4.4 is available. This update does nothing more than reinstate Quartz in the kodi repo.
Sorry for the inconvenience.
2018-12-08, 07:58
Last time the quartz skin was on the kodi repo, kodi was named xbmc
Thank you for uploading it and for bringing it back after so many years.
There are 2 questions I have thoough.
1) I had your skin installed in my kodi by git cloning your repo inside ~/.kodi/addons and then enabling it. That comes with the name skin.quartz.ce.leia. Do I have to remove it and install it from the repo now? I would like to follow its development through github...
2) Since there is no way to open an issue report on github now, I will ask here for a change I want. Can you please change that monospace font in system information to a... simple one like confluence has
2018-12-08, 11:47
(2018-12-08, 07:58)jim_p Wrote: [ -> ]1) I had your skin installed in my kodi by git cloning your repo inside ~/.kodi/addons and then enabling it. That comes with the name skin.quartz.ce.leia. Do I have to remove it and install it from the repo now? I would like to follow its development through github...CE is deprecated. You should be installing quartz from the kodi repo. You can follow the code here.
(2018-12-08, 07:58)jim_p Wrote: [ -> ]2) [...] Can you please change that monospace font in system information to a... simple one like confluence hasThere's a reason why most skins have switched to the mono font for sysinfo.
I understand it's a bit jarring seeing a different font in this window but it's confluence that is the outlier in this regard.
2018-12-08, 18:56
Thank you for the clarification on both issues
2018-12-16, 02:12
2018-12-22, 23:47
Is there a way to have the menus on the homepage do a randomized fanart rotation as background? I wasn't able to find such an option the skin's settings.
2018-12-23, 01:08
(2018-12-22, 23:47)lococola Wrote: [ -> ]Is there a way to have the menus on the homepage do a randomized fanart rotation as background?
Nope. I experimented with that while adding the home screen slide show feature. Wasn't happy with the results. I'm willing to revisit this if you can point me to a skin that does it right.
2018-12-26, 21:52
This is a great skin. Would it be possible to add the ability to deep dive into an add-on so I could assert a command within the add-on. For example, I would like to create a top level command that calls EmbyCon and goes directly to the entry for the stored TV recordings. That way my wife would not have to select EmbyCon/DVR/Show.
Rob
Rob
2018-12-26, 22:29
(2018-12-26, 21:52)robmich Wrote: [ -> ]This is a great skin. Would it be possible to add the ability to deep dive into an add-on so I could assert a command within the add-on. For example, I would like to create a top level command that calls EmbyCon and goes directly to the entry for the stored TV recordings. That way my wife would not have to select EmbyCon/DVR/Show.
Possibly. I assume this is a feature supported by embycon and that you have succeeded in doing this with another skin? If so, how was that accomplished?
2018-12-26, 22:42
Yes, I was able to deep dive into add-ons with the Titan Skin. It pretty much worked with any add-on I tried it on. For my current home theater plans your skin is exactly what I am looking for. In Titan, in the menu set-up screen, you could select an add-on and there was an option to either select opening the add-on at the top level or drop down a level (or more) and select an internal command.
Rob
Rob
2018-12-26, 22:59
Okay. I just installed embycon and then added it to kodi favourites. Examining the favourites.xml file I see there is a content_type parameter to the plugin call. Experiment with changing that and then assign the favourite to a sub-menu using the Home menus customizer found in skin settings.
You can scrutinize Titan's skin settings.xml file for clues on how to construct the command. Check out this thread for a primer on modding the home screen.
Let me know how it goes.
2018-12-26, 23:07
Thanks. I'm not great with XML, but I will see if i can figure it out.
Rob
Rob
