Full Version: QUARTZ - Leia
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
(2018-08-13, 20:03)Aaiemron Wrote: [ -> ]In the TVShow menu, (In skin settings in homemade shelf customiser) when you choose Auto populate, then you see the recent added episodes as a widget. Is it possible to change that in TVshows instead of Episodes? Or maybe on option to choose between episodes and TVshows?
In know you can add favorites as a widget, but in that case you see no posters or miniatures. Only an icon.
Let me see if I understand your question correctly. So if you add 2 episodes to a TV show named "ABC" you want to see only a single poster for ABC in the media shelf?
(2018-08-13, 21:46)nonJon Wrote: [ -> ]
Yes, if that's possible.
Not possible AFIK. Dynamic List Content populates the media shelf in Quartz. When recently added TV shows is the target... KODI is always going to return a list of episodes.
(2018-08-14, 00:44)nonJon Wrote: [ -> ]Not possible AFIK. Dynamic List Content populates the media shelf in Quartz. When recently added TV shows is the target... KODI is always going to return a list of episodes.
 Mmm, oke. Thanks for your answer.
(2018-08-12, 23:06)nonJon Wrote: [ -> ]Working on a skin theme named:
an·gu·lar
adjective
1.
(of an object, outline, or shape) having angles or sharp corners.
If you would like to preview and help test this, just drop this file in the skin's media folder and head on over to: Settings>Interface>Skin>Theme
Cheers!
Refreshed the file to capture a couple missed textures.
an·gu·lar
adjective
1.
 I like! I wasn't too wild about the rounded corners anymore, but it doesn't show very often. I much prefer this. Any particular screens to look for?
(2018-08-20, 15:23)mediumdry Wrote: [ -> ]Any particular screens to look for?
Nothing specific... just pipe up if you spot anything incongruous.
mediumdry? Please tell me that is a stipulation to your bartender! Wink
FYI, v5.4.1 is live.
(2018-08-08, 21:33)nonJon Wrote: [ -> ]I’m pleased to announce that Quartz has been added to the official repository for KODI 18 / Leia. Cool
Well done!
@Martijn
Quartz is conspicuously absent from the list of skins available for Beta 1. Wink
5.4.1 has a problem with angular for me, it doesn't show the angular box around the selection. It makes for a hard time using it...
Always on device? If so have you tried rebooting it?
(2018-08-31, 09:40)mediumdry Wrote: [ -> ]5.4.1 has a problem with angular for me, it doesn't show the angular box around the selection. It makes for a hard time using it...
Because you previewed the theme an open texture file was overwritten by the update. Cycling kodi should have resolved the issue. Is this still a problem for you?
rebooting seems to have fixed it indeed. Did you make the corners of the default theme a little bit less rounded?
(2018-09-06, 13:14)mediumdry Wrote: [ -> ]Did you make the corners of the default theme a little bit less rounded?
Nope. Didn't touch the default theme.
