Hi guys,
Can't figure out why Kodi crashes at launch. I've tried numerous times to uninstall and reinstall, no avail. Can anyone help?
Here is my Debug log:
https://pastebin.com/TpBUgJQg
Please remove the LibreELEC details in your signature. We're not a place for advertising banned add-ons.
That log doesn't have debug logging enabled.
Also please use a pastebin site for logs, not dropbox or other sites where stuff needs to be downloaded. Details in the next post.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
(2018-04-26, 19:46)DarrenHill Wrote: [ -> ]That log doesn't have debug logging enabled.
Thanks for taking the time to respond. Unfortunately, I cannot turn on debug. The instance I launch Kodi.exe, it crashes.
It can be done via an advancedsettings.xml file from outside Kodi.
Follow the link below to the wiki and see the advanced section for details of how to do it.
Debug log (wiki)
(2018-04-26, 20:10)DarrenHill Wrote: [ -> ]It can be done via an advancedsettings.xml file from outside Kodi.
Debug log (wiki)
Thank you! Here's the debug log:
Thank you for clearing that up.
