Full Version: Problem with the latest Milhouse x86 Build #429 "invalid break"
i'm having an error when playing recording since the latest builds.
None of the recordings are playing. In the logs i've found the following error:
17:56:52.233 T:139999021480064  NOTICE: VideoPlayer::OpenFile: pvr://recordings/tv/active/Texas%20Jail%20-%20Unter%20Arrest, TV%20(DMAX%20HD), 20180430_104500, 1888.pvr
17:56:52.234 T:139996590954240  NOTICE: Creating InputStream
17:56:52.268 T:139996590954240  NOTICE: Creating Demuxer
17:56:52.470 T:139996590954240  NOTICE: Opening stream: 0 source: 256
17:56:52.470 T:139996590954240 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
17:56:52.470 T:139996590954240  NOTICE: Opening stream: 1 source: 256
17:56:52.470 T:139996590954240  NOTICE: Finding audio codec for: 86019
17:56:52.470 T:139996590954240  NOTICE: Creating audio thread
17:56:52.470 T:139996582561536  NOTICE: running thread: CVideoPlayerAudio:Tonguerocess()
17:56:52.476 T:139996590954240  NOTICE: Opening stream: 0 source: 256
17:56:52.476 T:139996590954240  NOTICE: Creating video codec with codec id: 27
17:56:52.476 T:139996590954240  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:56:52.476 T:139996590954240  NOTICE: Creating video thread
17:56:52.476 T:139996574168832  NOTICE: running thread: video_thread
17:56:52.476 T:139996590954240   ERROR: AddCut - Times are around the wrong way or the same! [02:19:04.436 - 02:19:04.436], 0
17:56:52.476 T:139996590954240   ERROR: ReadPvr - Invalid break [02:19:04.436 - 02:19:04.436] found in PVRRecording for: pvr://recordings/tv/active/Texas%20Jail%20-%20Unter%20Arrest, TV%20(DMAX%20HD), 20180430_104500, 1888.pvr. Continuing anyway.
17:56:52.476 T:139996590954240   ERROR: AddCut - Times are around the wrong way or the same! [02:19:04.436 - 00:00:00.000], 0
17:56:52.476 T:139996590954240   ERROR: ReadPvr - Invalid break [02:19:04.436 - 00:00:00.000] found in PVRRecording for: pvr://recordings/tv/active/Texas%20Jail%20-%20Unter%20Arrest, TV%20(DMAX%20HD), 20180430_104500, 1888.pvr. Continuing anyway.
17:56:52.477 T:139996590954240  NOTICE: Opening stream: 1 source: 256
17:56:52.483 T:139996565776128  NOTICE: COutput::OnStartup: Output Thread created
17:56:52.599 T:139999021480064  NOTICE: GL: Selecting YUV 2 RGB shader
17:56:52.608 T:139999021480064  NOTICE: GL: NPOT texture support detected
17:56:52.608 T:139999021480064  NOTICE: GL: Using GL_ARB_pixel_buffer_object
17:56:52.608 T:139999021480064  NOTICE: Using GL_TEXTURE_2D
Is this because of api changes?
Thank you in advance
kafisc
Please paste a complete log. Makes diagnose much more easier.
Oh and enable debug mode beforehand
Thank's for your reply.  Here's the dubug log: https://paste.ee/p/43dmu#
Thanks, this is fixed!
