Full Version: Analyzing log in debug
I would like to know the reason for the logs below
CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-11831.867893, adjusted:-11831.867893
 Can anyone explain?
(2018-05-01, 19:44)tetramarreta Wrote: [ -> ]for the logs below
Logs? I see only two lines of text...
Get us a full debug log (wiki) via pastebin.com (or similar upload websites) so we can see some more context to your two log lines.
(2018-05-01, 20:05)Klojum Wrote: [ -> ]
I just wanted to know the reason for these lines.
the platform could be relevant and what kind of stream it was (like, was it handled via inputstream.adaptive, ...)
(2018-05-01, 19:44)tetramarreta Wrote: [ -> ]I would like to know the reason for the logs below
The measured timestamps are clean, frame duration is 41708.33 -> 23.976 fps
(2018-05-01, 19:44)tetramarreta Wrote: [ -> ]CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-11831.867893, adjusted:-11831.867893
 Can anyone explain?
Passthrough audio can't be speed up or slowed down to adjust a/v synchronization. In order to sync audio/video, audio slightly changes the clock and video has to adapt. In this case clock was changed by 11.8 milliseconds
(2018-05-02, 07:54)da-anda Wrote: [ -> ]the platform could be relevant and what kind of stream it was (like, was it handled via inputstream.adaptive, ...)
 I'm running on android, inputstream
(2018-05-02, 09:13)FernetMenta Wrote: [ -> ]
 Can anyone explain?
Thank you so much.
Is there any documentation on how the video player works, something well didactic?
(2018-05-03, 04:18)tetramarreta Wrote: [ -> ]
 Can anyone explain?
Thank you so much.
Yes, the source code Smile
(2018-05-03, 07:33)FernetMenta Wrote: [ -> ]
(2018-05-02, 09:13)FernetMenta Wrote: [ -> ]The measured timestamps are clean, frame duration is 41708.33 -> 23.976 fps
Thank you so much.
I already learned a lot in the source code.
Hugs
