Full Version: Times in Kodi 18 seem bad
Working on skinning for Kodi 18.  I'm having problems with pvr.wmc client.  The following gui infos return bad data while playing live tv or playing an actively recording tv:
PVR.EPGEventElapsedTime
PVR.TimeShiftCurrent
PVR.TimeShiftOffset
PVR.TimeShiftEnd
Also I find it impossible to seek forward in live tv (for example, pause live tv in Kodi then later resume, or open a recording that's in progress).
scott s.
Yes, you are right the times are messed up.  Kodi's pvr interface was in a state of flux on this and I figured I wouldn't make changes until it was resolved.  Actually though, I haven't heard anything about this since around January on the thread I was following so possibly the status has changed and I have not heard about it.
I am not sure what is going on with seek though, I don't think the above should effect it.  If you can provide a log where you show the problem (just this problem to keep it short) I could take a look.
