Full Version: Foreground Wiki Skin- Report Issues
Foreground is a new skin being tested for suitability as the default skin for the Kodi Wiki.
To test this skin, go to your Preferences, and under Appearance tab select the Foreground Skin.
If you notice any glitches or issues, please report them in this thread.
Summary of reports
Any Team Member is free to edit this page
The following is a summary of the bug reports from this and other threads.
Do not post a problem if it is already listed here
If you post an issue in this thread, and would like it included in this list, then provide a statement of the problem in 20 words or less.
Current Issues
  1. NavBoxes and Mininavs are oversized. See https://kodi.wiki/view/Naming_video_files
  2. Icons and text are offset from each other. See main page for example.
  3. Everything seems oversized. Can we reduce line spacing and font sizes.
  4. Spacing in the <Index two column> and <index three column> templates need to adjusted as columns run into each other. See here... https://kodi.wiki/view/Video_management
  5. Change the Recent Changes page from centered to left justified... https://kodi.wiki/view/Special:RecentChanges
  6. Code boxes are not visible and text within them simply looks like the
Resolved Issues
  1. Forbidden characters in the TOC Section Headers no longer applies.
Getting rid of the menu bar on the left is a big plus on smaller screens (1280x800 laptop here). There is more room for the actual content. The current issues seem to be even worse on a smaller screen.
