Hi guys i have one show that kodi don't find, but it should i have the same name that on thetvbd.com (i've tried multiple spelling because of the french ê )
https://www.thetvdb.com/series/343381
(with my setup it was easier than a screenshot)
Hello @
kevindery
The screenshot is useful as it not only shows you have correctly named the folder, but it also shows you have incorrectly setup your Source.
A
Debug Log is also needed to see what the scraper is doing. At a guess at this stage, I would say the
ê is the issue, but we can confirm with the debug log.
Quick instructions here...
- Enable Debugging mode. Go to Settings>System Settings>Logging and it should be the first option
- Restart Kodi
- Replicate the problem. Try to scan the show into the library.
- Upload the results to https://pastebin.com/ or https://paste.ubuntu.com/ and link back here.
If somebody have the same problem
the scraper have language option
- Settings>Media>Library>Videos
- "C" on the tv show>change content
- Settings
- Language>set the right language
- SUCCESS!
