I have been using Leia nightly's but decided to try Leia Alpha 1 but it fails to install. Should it install over the nightly builds.
I have a Minix U1 and am trying to load Arm 7A 32 bit.
Current nightlies have a higher version number then Leia Alpha 1 and android doesn't allow to downgrade to a lower version.
So you have to first uninstall Kodi to be able to reinstall Leia Alpha 1.
Thanks Rechi, i appreciate the reply.
I have been using the nightly builds but sometime after March up until now the nightly's stopped working correctly.
When I download a new nightly it loads on my Minix U1 but every time I go back to the Minix home screen the only way I can go back into Kodi is to delete the cache.
I try a new nightly frequently but no luck so I am running a nightly from the end of March.
