Hey all. i'm trying to uninstall a corrupted version of Kodi and reinstall the latest version but kodi isn't showing up in my Windows programs list and there's no uninstall exe that I can find in the directory.
If you installed it using the windows store you will find it listed in the apps menu where you will right click on it and select uninstall from the drop down menu.
No, I installed it by downloading it and running the installer. I double checked my apps to be sure and the kodi app isn't installed.
