Full Version: Create variables
i wanna create 2 variables in variable.xml file and wanna give the text under skin settings.
Which code should I use in settings and in which file should I add the codes for settings. Under variable.xml I habe the id wellcome_text
and wanna call it from skin any times. I need only the code for setting window, how can user give the text directly self.
kind regards
