2018-05-15, 14:15
Infos about my problem and build.
See log file here.
- System is AMD threadripper whereby I've cloned the drive from the old Intel system to this. I doubt it's a driver issue as I don't have any other programs crash like kodi does.
- The crash happens on all files. Approx 3-5 seconds after playback has started and sometimes will navigating the UI.
- I installed the nightly builds and the same happened so I've tried to roll back to 17.6 and it's the same result.
- I've enabled portable mode by adding -p switch in the shortcut target.
- Completly fresh install.
See log file here.
