2018-05-17, 10:44
Hello,
I am using TVH to record all my TV shows, to a folder called "Videos".
I set the content to TV in Kodi, but have noticed that for various reasons, not everything is showing up in the TV shows menu.
I have instead found it easier just to go into Videos/Files/Videos and everything is there with its original file name - I watch everything from here instead.
The problem with this is that when I have marked all the files within the parent folder as watched, the folder itself does not get a watched tick. However, if I do exactly the same thing via the TV Shows menu (i.e. in library mode) and then look at the parent folder via Videos, it becomes ticked.
What is the reason for this difference and is there any way to change it?
