I have a raspberry pi3 with kodi 17.something. And lately I have been having problems when watching videos I suddenly get like white static screen and then black screen and audio cuts, just för a second or two. Then It continous to play. Before this happened maybe once every 20 video. Now It happens several times in every video. Anyone have an idea whats going on? Im really no expert on the Rasp. Mostly just use it to watch videos from a external harddrive.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
