Full Version: Since nightly build 20180516 Kodi no longer plays AVI on a Fire TV and sudden stops
Describtion:
Since nightly build kodi-20180516-afaf815f Kodi no longer plays AVI on a Fire TV. This is probably due to the recent changes in DVDAudioCodecAndroidMediaCodec or in connection with these.
H.264 and HEVC files still work without problems. Update: Since the build, these files also often have black screens while playing and playback is automatically stopped.
Last working version is:
kodi-20180514-8e9cb51d
Detected on:
Fire TV 4k box
Example file that is no longer played - permanently rotating load symbol:
test.avi
General
Complete name                  : test.avi
Format                         : AVI
Format/Info                    : Audio Video Interleave
File size                      : 175 MiB
Overall bit rate mode          : Variable
Overall bit rate               : 1 925 kb/s
Writing application            : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                : VirtualDubMod build 2540/release
Video
Format                         : MPEG-4 Visual
Format profile                 : Advanced [email protected]
Format settings                : BVOP1
Format settings, BVOP          : 1
Format settings, QPel          : No
Format settings, GMC           : No warppoints
Format settings, Matrix        : Default (H.263)
Codec ID                       : XVID
Codec ID/Hint                  : XviD
Duration                       : 12 min 40 s
Bit rate                       : 1 766 kb/s
Width                          : 640 pixels
Height                         : 352 pixels
Display aspect ratio           : 16:9
Frame rate                     : 25.000 FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 0.314
Stream size                    : 160 MiB (92%)
Writing library                : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format                         : MPEG Audio
Format version                 : Version 1
Format profile                 : Layer 3
Format settings                : Joint stereo
Codec ID                       : 55
Codec ID/Hint                  : MP3
Bit rate mode                  : Variable
Bit rate                       : 146 kb/s
Channel(s)                     : 2 channels
Sampling rate                  : 48.0 kHz
Stream size                    : 13.2 MiB (8%)
Alignment                      : Aligned on interleaves
Interleave, duration           : 24  ms (0.60 video frame)
Interleave, preload duration   : 110  ms
Writing library                : LAME3.98.4
Log-Dump:
NOTICE: VideoPlayer::OpenFile: smb://FRITZ-NAS/FRITZ.NAS/Mediaserver/test.avi
 ERROR: CDVDAudioCodecAndroidMediaCodec::GetData ExceptionCheck; dequeueOutputBuffer
                java.lang.IllegalStateException
 ERROR: Previous line repeats 1 times.
NOTICE: Using GL_TEXTURE_2D
NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
 ERROR: Previous line repeats 14 times.
NOTICE: Creating InputStream
 ERROR: Previous line repeats 21 times.
NOTICE: Creating Demuxer
 ERROR: Previous line repeats 55 times.
NOTICE: Opening stream: 0 source: 256
NOTICE: Creating video codec with codec id: 12
NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
NOTICE: Opening stream: 1 source: 256
NOTICE: Finding audio codec for: 86017
 ERROR: SOCK: Error selecting socket(s)
 ERROR: ES: Exception caught while listening for socket
NOTICE: ES: UDP Event server stopped
test.avi added
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
@Karellen here is the debug.log Kodi.log
I can confirm I had the same issue with some .avi files with the latest nightly build, Nvidia Shield TV, and have rolled back to the 20180514 and the files are now playing.
Unfortunately I am not in the position to provide a debug log as I am out but will try to get one up later.
Sorry I did the chance to do it on my Amazon TV. Hope I’ve done it right.
Works enawutocut (paste)
Don’t work warelecele (paste)
Same problem with latest nightly on Nvidia Shield. My .avi files does not start.
Thanks - open a trac ticket. Kodi on Android is currently not maintained - therefore nobody is looking into that.
Make sure to add a Debug Log to the ticket and also check what happens when Mediacodec is completely disabled.
(2018-05-20, 16:29)fritsch Wrote: [ -> ]Thanks - open a trac ticket. Kodi on Android is currently not maintained - therefore nobody is looking into that.
Debug.log
Without Mediacodecs it doesn't work either. I suspect the reason is PR#13900.
Here's trac ticket: 17883
We should try tomorrow using this night nightlies that should include this 13924 (PR) that should solve.
Problem solved with this night nightly build (kodi-20180524).
Thread can be marked as solved.
Thanks Kodi!!!
