Look at this,
https://imgur.com/a/e5qviSH
I had to donate to get these scrappers to unlock. What gives? Is it a scam or what.
If you say tvdb is enough, I wouldn't have donated. Come on devs.
Come on @
clockwerk
How about you show a bit of respect and appreciation for the work that is being done. If you find an issue, then submit a respectful bug report. There is no need to be accusing people of scamming.
Or you will find you will be out on your ass pretty quick!
Our AniDB scraper works.
"Soul Eater" finds something here and works fine.
Please upload logfile to some pastebin site...
Kodi scrapers are bit different, though.
We cannot guarantee if they work 100% (some do, others not)
(They might take a bit longer to activate the OK button, since the workflow/scrape is different)
Please test, if they scrape inside Kodi fine...
myron
Thanks for the fast reply. After rebooting my pc, anidb indeed works, my fault. For kodi scrappers, it would help if you could document the part where it doesn't work 100% or even omit it in your software. That would make it much better.
Another problem I'm facing. Look here,
https://imgur.com/a/LhMq36T
As you can see, season 1 has no problem scrapping 01-26. But when it comes to season 2, it starts with S02E27 rather than S02E01. Anyway I could change this?
Is there anyway to make your software scrape using
absolute order? TVDB has no problems searching in absolute order, it will change to seasons automatically. Is your software not implementing this feature? Look here for what I'm talking about,
https://imgur.com/a/2K9DLAZ
