Full Version: Unable to play any TV channel
Hello.
I'm using RaspberryPi 3 and Kodi v17.3
I installed PVR IPTV Simple Client.
I followed this article @Karellen- Link removed  and links provided there @Karellen- Link removed
After I restarted Kodi ... it loaded around 3000 channels.
They are nicely listed but none of it is working Smile
I mean I don't have any error or message but simply I click on any channel but it does not start.
Could someone help me?
My goal is quite simple: I want to see that I could play TV.
Maybe my link to m3u list is not good? Could you recommend me one ... just to verify it works for me ?
Thanks a lot ..
@Susja
I have removed your links as the first one links to a site that also advertises add-ons that are banned here, and the second one is a list of copyright infringing channels.
We will not be able to assist you with your query. Kodi does not supply movies, tv shows, tv channels, m3u lists or any other type of media. If you followed that guide, then the person to ask is the author of that guide.
Good luck. Smile
