2018-05-23, 23:44
Hello, I am testing the software a bit. Above all, I test the IPTV of the Fritzbox 6490 Cable (KDG/Vodafone) what I can then stream into the network on different devices. Since I do not use my XBox One often, I'm glad Kodi finally works on it.
Addon: IPTV Simple Client with sender logos and EPG
- local: Works (share files via NFS "PC to Xbox and Xbox to PC)
- Network: Works
Thanks for your Work
m3u for Fritzbox 6490 Cable (KDGVodefone - Berlin) (a little work ..... SD = Done - HD Channels = in work)
- Network: Works
