2018-05-27, 01:31
Hi all,
I wanna change the installation order from kodi with changing this code under apktool.yml :
to :
what doesn't work with kodi 18 nightly version.
And another issue, if I change the addons folder under assets folder, it will not install with first run.
Should I do anything else also ?
Thx a lot.
isFrameworkApk: false
packageInfo:
forcedPackageId: '127'
renameManifestPackage: none
to :
packageInfo:
renameManifestPackage: org.xbmc.test
Thx a lot.
