Full Version: Keep some text in the Movie name or have a custom name?
Is there anyway for Ember to keep a part of the file name if a particular word is in it?
i.e. I a previous tool I used, if it saw "Dolby Atmos" in the file name it keeped it in there...
i.e. Kong- Skull Island - Dolby Atmos (2017) would be the file name....
also, is there anyway to have a custom name?
i.e. The Lost World - Jurassic Park change to Jurassic Park - The Lost World
Is there a way to choose from AKA lists etc?
Thanks,
Matt
(2018-05-28, 07:42)ping182nz Wrote: [ -> ]Is there anyway for Ember to keep a part of the file name if a particular word is in it?
No.
But you can use the audio codec in the renamer.
(2018-05-28, 07:42)ping182nz Wrote: [ -> ]also, is there anyway to have a custom name?
No. You can set an preferred title "language" in the IMDB scraper settings, but in your example it is a "working" title and that isn't available as languague/country.
Just to add to Dan's answer, you can change the name of a movie in the edit window to what ever you want manually
And you can lock it from context menu so Ember dosn't change it if you  do a complete rescan of your library
