Full Version: Error editing timer rules
Hello, I get an error when editing some timer rules, I can change the rules in the dialog box but on pressing "ok" get the message:
"An unexpected error occurred. Try again later or check the log for more information."
Log is at link below if anyone can take a look, attempting to edit the rule for programme 'Back' around 22:25.
Looks like it cannot find an epg entry, but obviously many timer rules will not have an epg entry available within the guide data time frame at any given time..
log link
Hi, it seems your original rule have been based on an EPG entry. If the EPG entry is deleted from the guide then the addon cannot retrieve required info to update the schedule. To fix that issue you have to update the timer type to "Manual" and complete missing or invalid data.
