I don't know what had happened. But after recent Windows 10 updates. KODI doesn't seem to work properly anymore. App would freeze and crash often, mostly 10 minutes. This is very annoying. Does anyone having the same problem? Please tell me what to do.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
