2018-06-07, 21:36
Hi there,
I run into another issue and need a bit help with it.
I like to use Super Favourites to create a custom Folder with my most used Addons/Plugins and use this folder as a Favorite Link to be able to get it shown as a widget. That is working so far. The problem I have is, I can't launch any of the shown Addons via the widget.
I also have tried to just put the complete "Video Addons" Folder to Favourites and use that link for the widget. With that I am able to launch the Addons. To be sure its not the Super Favourites link that causes the issue I was checking the Artic Zephyr Skin where I can also create custom Widgets which are linked via Favorites. There the Favourite link to my Super Favourites Custom Folder also works and I am able to launch the Addons.
So I guess it has to do something with my "<onclick>" command I am using.
This command is working fine with the widget when its linked to:
But when I using the link to Super Favourites:
I checked the xml files from Artic Zephyr Skin how its done there, but couldn't find anything that helped.
Thanks again for your time and help
xml:<onclick>RunAddon($INFO[Container(10010).ListItem.Property(Addon.ID)])</onclick>
xml:<content target="addons">addons://user/xbmc.addon.video</content>
I am not able to launch any of the addons shown in the widget (*xyz is my created custom folder for testing).xml:<content target="addons">plugin://plugin.program.super.favourites/?label=xyz&mode=400&path=special%3%2F%2Fprofile%2Faddon_data%2Fplugin.program.super.favourites%2FSuper%20Favourites%2Fxyz&sf_options=fanart%3DNULL%26_options_sf",return)</content>
