Hello: After a successful Kodi install, I keep receiving the "could not connect to repository, etc." message each time I attempt to complete an add-on. Can someone please tell me how to avoid or fix this issue so I can successfully install my addons?
Appreciate any help.
Thank you.
oaky
(2018-06-07, 22:40)oaky Wrote: [ -> ]I keep receiving the "could not connect to repository, etc."
Which repository are you trying to connect to? Provide the address and I will test it.
And a
debug log (wiki) of such an attempt, uploaded to a PasteBin site and linked to here would probably be useful too.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
