2018-06-10, 13:40
I am using for years succesfully a configuration with different kodi-(and forks) clients. They all access on one central mysql database on a synology discstation.
This worked since some days ago until i started to update some android-kodi 18 versions and libreElec versions.
All these versions crashing now, when I enable the wake up remote server / wake on lan functionality. I have to disable it or I can let it enabled but I have to delete the wakeonlan.xml in userdate-folder. My assumption is - that this will not work reliable.
I think the last successfully used kodi leia version was from end of march.
Any idea what i can do? is it a know bug? Of course, I tried to find information - but i did not find anything about it.
SaEt9000
SaEt9000
