I am using Kodi + DVBViewer Client add-on on Android TV. PVR channel 'Das Erste HD' is only software decoded which is not feasible on the slow SoC. Weird thing is that other 720p50 channels are properly being HW decoded (like 'ORF 1 HD').
I am attaching a log where I first set 'ORF 1 HD' (HW decoded) and then 'Das Erste HD' (only SW decoded).
LOG]
I can confirm this on windows too. Sine last year middle of October i have this issue to. Running only without DXVA2 is ok and i don´t want to run with sync to display mode due to missing passthrough.
Log
(2018-06-16, 12:27)tehax Wrote: [ -> ]I can confirm this on windows too. Sine last year middle of October i have this issue to. Running only without DXVA2 is ok and i don´t want to run with sync to display mode due to missing passthrough.
Log
Not sure what you confirm. For Live content passthrough is disabled.
Right, sync to display setting can only be set global for all media not individual. So when i set sync to display pvr runs flawless but for movies i have no bitstream audio.
I can confirm that with DXVA2 on "Das Erste" is not watchable due to stuttering. May my post here is the wrong place, sorry.
(2018-06-16, 17:10)tehax Wrote: [ -> ]Right, sync to display setting can only be set global for all media not individual. So when i set sync to display pvr runs flawless but for movies i have no bitstream audio.
The OP has the problem, that hw decoder is NOT working, cause his hw decoder is opened twice during start of stream. And cause it is implemented as a singleton (MediaCodec Surface) or some hw only supports on decoder / render ctx at once -> it fails.
should be fixed in master
Fixed. 'Das Erste HD' now uses 'amc-h264(S)' video decoder again. Thanks.
