Full Version: Can't Start Event Server On Fedora 28
I have Kodi installed on my server running Fedora 28 and it consistently fails to start the Event Server (Remote Communications Server) so that I can control it with my phone. I have SE Linux disabled, and iptables is running (I have Docker containers running) but I have it set to allow all TCP and UDP packets so I'm not sure what the issue is, I've tried multiple ports but that doesn't have any effect.
As soon as I select Allow remote control from applications on other systems I get the Failed to start alert box and when I close it, Kodi freezes. This is what the debug log shows when I select the option and then close the dialog box.
21:32:24.166 T:139863356622080   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:32:24.266 T:139863356622080   DEBUG: OnKey: return (0xf00d) pressed, action is Select
21:32:24.266 T:139863356622080  NOTICE: ES: Stopping event server with confirmation
21:32:24.708 T:139861145048832   DEBUG: Thread JobWorker 139861145048832 terminating (autodelete)
21:32:24.941 T:139860190926592  NOTICE: ES: UDP Event server stopped
21:32:24.941 T:139860190926592   DEBUG: Thread EventServer 139860190926592 terminating
21:32:24.941 T:139861145048832   DEBUG: Thread EventServer start, auto delete: false
21:32:24.941 T:139861145048832  NOTICE: ES: Starting UDP Event server on port 9777
21:32:24.941 T:139863356622080   ERROR: JSONRPC Server: Failed to connect to sdpd
21:32:24.942 T:139863356622080   DEBUG: JSONRPC Server: Failed to bind ipv6 serversocket, trying ipv4
21:32:24.942 T:139863356622080   ERROR: JSONRPC Server: Failed to bind ipv4 serversocket
21:32:24.942 T:139863356622080   DEBUG: ------ Window Init (DialogConfirm.xml) ------
21:32:31.233 T:139863356622080   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:32:31.333 T:139863356622080   DEBUG: OnKey: return (0xf00d) pressed, action is Select
21:32:31.333 T:139863356622080   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:32:31.501 T:139863356622080   DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
21:32:31.533 T:139863356622080   ERROR: Create - fatal error creating thread EventServer - old thread id not null
21:32:31.534 T:139860629137152   DEBUG: Thread Timer 139860629137152 terminating
21:32:31.534 T:139861669291776   DEBUG: Thread PeripEventScanner 139861669291776 terminating
21:32:31.588 T:139861694469888   DEBUG: Thread PeripBusUSBUdev 139861694469888 terminating
21:32:31.981 T:139861677684480   DEBUG: Thread PeripBusAddon 139861677684480 terminating
21:32:31.982 T:139861686077184   DEBUG: Thread PeripBusCEC 139861686077184 terminating
21:32:31.984 T:139862732826368   DEBUG: Failed to connect to LIRC. Giving up.
21:32:31.984 T:139862732826368   DEBUG: Thread RemoteControl 139862732826368 terminating
Full log: https://pastebin.com/CfymezHU
Tried a "netstat" (or lsof) to check there's not already something running on that port (9777)...?
