Full Version: Kodi Cross compiling for ARMv7 with Ubuntu 16.04 LTS
Build host is Ubuntu 16.04 with gcc 8.1.0 cross toolchain armv7 NEON optimization enabled, target is Asus Tinkerboard, Leia master branch.
I basically follow git's README.raspberrypi without --with-firmware=$RPI_DEV/firmware and --with-platform=raspberry-pi2 in ./configure.
Dependencies built successfully as follow:
Quote:xbmc/tools/depends$ ./configure --host=arm-unknown-linux-gnueabi \
--build=i686-pc-linux-gnu \
--prefix=/usr/local/src/kodi-bcm \
--with-toolchain=/opt/x-tools/arm-unknown-linux-gnueabi \
--disable-debug
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-linux-gnueabi
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether g++ supports C++11 features by default... no
checking whether g++ supports C++11 features with -std=c++11... yes
checking for ccache... yes
checking for curl... /usr/bin/curl
checking for tar... /bin/tar
checking for arm-unknown-linux-gnueabi-ranlib... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ranlib
checking for arm-unknown-linux-gnueabi-ld... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ld
checking for arm-unknown-linux-gnueabi-ar... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ar
checking for arm-unknown-linux-gnueabi-readelf... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-readelf
checking for arm-unknown-linux-gnueabi-strip... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-strip
checking for arm-unknown-linux-gnueabi-as... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-as
checking for arm-unknown-linux-gnueabi-nm... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-nm
checking for arm-unknown-linux-gnueabi-objdump... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-objdump
checking for arm-unknown-linux-gnueabi-gcc... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc
checking for arm-unknown-linux-gnueabi-g++... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-g++
checking how to run the C preprocessor... /opt/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc -E
checking for ranlib... /usr/bin/ranlib
checking for ld... /usr/bin/ld
checking for ar... /usr/bin/ar
checking for readelf... /usr/bin/readelf
checking for strip... /usr/bin/strip
checking for as... /usr/bin/as
checking for nm... /usr/bin/nm
checking for objdump... /usr/bin/objdump
checking for gcc... /usr/bin/gcc
checking for g++... /usr/bin/g++
checking for library containing iconv_open... none required
checking for arm-unknown-linux-gnueabi-ccache... no
checking for ccache... /usr/bin/ccache
configure: WARNING: using cross tools not prefixed with host triplet
configure: creating ./config.status
config.status: creating target/config.site
config.status: creating native/config.site.native
config.status: creating Makefile.include
config.status: creating target/Toolchain.cmake
config.status: creating target/config-binaddons.site
config.status: creating target/Toolchain_binaddons.cmake
config.status: creating target/cross-file.meson
use simulator:
'target/config.site' -> '/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/share/config.site'
'target/config-binaddons.site' -> '/usr/local/src/kodi-bcm/i686-linux-gnu-native/share/config-binaddons.site'
'target/Toolchain.cmake' -> '/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/share/Toolchain.cmake'
'target/Toolchain_binaddons.cmake' -> '/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/share/Toolchain_binaddons.cmake'
'target/cross-file.meson' -> '/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/share/cross-file.meson'
'native/config.site.native' -> '/usr/local/src/kodi-bcm/i686-linux-gnu-native/share/config.site'
#------- configuration -------#
ccache:          yes
build type:      release
toolchain:       /opt/x-tools/arm-unknown-linux-gnueabi
cpu:             arm
host:            arm-unknown-linux-gnueabi
cflags:          -fPIC -DPIC  -Os
cxxflags:        -std=c++11 -fPIC -DPIC  -Os
ldflags:         -Wl,-rpath-link=/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/lib
ffmpeg options:
prefix:          /usr/local/src/kodi-bcm
depends:         /usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release
samson@37f0f5c53325:/usr/local/src/xbmc/tools/depends$
Running custom install script '/bin/sh /usr/local/src/xbmc/tools/depends/target/libinput/arm-unknown-linux-gnueabi-release/src/libinput-restore-selinux-context.sh /usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/lib /usr/local/src/xbmc/tools/depends/target/libinput/arm-unknown-linux-gnueabi-release/build/libinput.so.10.13.0'
Running custom install script '/usr/local/src/xbmc/tools/depends/target/libinput/arm-unknown-linux-gnueabi-release/tools/install-compat-scripts.sh /usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/bin'
touch .installed-arm-unknown-linux-gnueabi-release
make[2]: Leaving directory '/usr/local/src/xbmc/tools/depends/target/libinput'
Dependencies built successfully.
However, I failed to complete the "make -C tools/depends/target/cmakebuildsys" with the following error:
Quote:$ make -C tools/depends/target/cmakebuildsys
make: Entering directory '/usr/local/src/xbmc/tools/depends/target/cmakebuildsys'
mkdir -p /usr/local/src/xbmc/build
cd /usr/local/src/xbmc/build; /usr/local/src/kodi-bcm/i686-linux-gnu-native/bin/cmake -DCMAKE_TOOLCHAIN_FILE=/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release/share/Toolchain.cmake -DCMAKE_INSTALL_PREFIX=/usr/local/src/kodi-bcm/arm-unknown-linux-gnueabi-release -DCMAKE_BUILD_TYPE=Release -DENABLE_INTERNAL_CROSSGUID=OFF -DENABLE_INTERNAL_FFMPEG=OFF  /usr/local/src/xbmc
-- Source directory: /usr/local/src/xbmc
-- Build directory: /usr/local/src/xbmc/build
-- Generator: Single-configuration: Release (Unix Makefiles)
-- CMake Version: 3.9.4
-- System type: Linux
-- Linker: GNU gold
-- Core system type: linux
-- Platform:
-- CPU: arm, ARCH: arm
-- Cross-Compiling: TRUE
-- Execute build artefacts on host: FALSE
-- Depends based build: 1
-- Could not find hardware support for SSE (missing: _SSE_TRUE _SSE_OK)
-- Could not find hardware support for SSE2 (missing: _SSE2_TRUE _SSE2_OK)
-- Could not find hardware support for SSE3 (missing: _SSE3_TRUE _SSE3_OK)
-- Could not find hardware support for SSSE3 (missing: _SSSE3_TRUE _SSSE3_OK)
-- Could not find hardware support for SSE4.1 (missing: _SSE41_TRUE _SSE41_OK)
-- Could not find hardware support for SSE4.2 (missing: _SSE42_TRUE _SSE42_OK)
-- Could not find hardware support for AVX (missing: _AVX_TRUE _AVX_OK)
-- Could not find hardware support for AVX2 (missing: _AVX2_TRUE _AVX2_OK)
-- NEON optimization enabled
-- Could NOT find Avahi (missing: AVAHI_CLIENT_LIBRARY AVAHI_COMMON_LIBRARY AVAHI_CLIENT_INCLUDE_DIR AVAHI_COMMON_INCLUDE_DIR)
-- Could NOT find Bluetooth (missing: BLUETOOTH_LIBRARY BLUETOOTH_INCLUDE_DIR)
-- Could NOT find CAP (missing: CAP_LIBRARY CAP_INCLUDE_DIR)
-- Could NOT find LCMS2 (missing: LCMS2_LIBRARY LCMS2_INCLUDE_DIR)
-- Could NOT find LircClient (missing: LIRCCLIENT_LIBRARY LIRCCLIENT_INCLUDE_DIR)
-- Could NOT find MDNS (missing: MDNS_LIBRARY MDNS_INCLUDE_DIR)
-- Could NOT find PulseAudio (missing: PULSEAUDIO_LIBRARY PULSEAUDIO_MAINLOOP_LIBRARY PULSEAUDIO_SIMPLE_LIBRARY PULSEAUDIO_INCLUDE_DIR) (Required is at least version "2.0.0")
-- Could NOT find Sndio (missing: SNDIO_LIBRARY SNDIO_INCLUDE_DIR)
-- Could NOT find VAAPI (missing: VAAPI_libva_LIBRARY VAAPI_libva-drm_LIBRARY VAAPI_libva_INCLUDE_DIR VAAPI_libva-drm_INCLUDE_DIR VAAPI_libva-x11_INCLUDE_DIR VAAPI_libva-x11_LIBRARY) (Required is at least version "0.39.0")
-- Could NOT find VDPAU (missing: VDPAU_LIBRARY VDPAU_INCLUDE_DIR)
CMake Error at /usr/local/src/kodi-bcm/i686-linux-gnu-native/share/cmake-3.9/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find GLX (missing: GLX_LIBRARY GLX_INCLUDE_DIR)
Call Stack (most recent call first):
  /usr/local/src/kodi-bcm/i686-linux-gnu-native/share/cmake-3.9/Modules/FindPackageHandleStandardArgs.cmake:377 (_FPHSA_FAILURE_MESSAGE)
  cmake/modules/FindGLX.cmake:27 (find_package_handle_standard_args)
  cmake/scripts/common/Macros.cmake:374 (find_package)
  cmake/scripts/common/Macros.cmake:442 (find_package_with_ver)
  CMakeLists.txt:175 (core_optional_dep)
-- Configuring incomplete, errors occurred!
See also "/usr/local/src/xbmc/build/CMakeFiles/CMakeOutput.log".
See also "/usr/local/src/xbmc/build/CMakeFiles/CMakeError.log".
Makefile:16: recipe for target 'all' failed
make: *** [all] Error 1
make: Leaving directory '/usr/local/src/xbmc/tools/depends/target/cmakebuildsys'
Your advices/hints on how to overcome the above errors is much appreciated.
cant crosscompile anymore for android aarch64 too
ok got it working, after third time beginning from scratch its now working, idk what happened between Smile
