2018-06-18, 21:52
2018-06-18, 21:55
and i've downgraded versions too.
2018-06-19, 00:23
@Armywolve
A very short log and stops on display checks which is indicative of graphics card/driver issues. The AMD Radeon HD 8650G is not that old so maybe checking your drivers and installing updated vendor drivers may fix the issue?
2018-06-19, 03:40
Thanks i'll try that out.
2018-06-19, 06:12
nope my drivers are up to date, my drivers are Legacy drivers which means they stopped pushing out new updates. so there's no work around? i cant run kodi?
2018-06-19, 09:45
I just read your thread title... Win - I've tried to do .xml, downloading 2015&17 C++, keeps crashing
What does that mean? What xml thing are you doing? What is with the 2015 C++ ?
You could test v16.1 and see if that works... http://mirrors.kodi.tv/releases/windows/win32/old/
2018-06-19, 11:09
i read the forms if the files wasn't doing crash logs you could advancedsetting.xml in userdata/appdata, and i've also read visual c++ redistributable could fix crash issues so i downloaded 15/17, i got it to work since my build has two types of graphics, and there's really no way or tool to do switchable graphics, i just went into device manger and disabled one. and boom kodi works, thanks.
2018-06-19, 11:22
Thread marked solved.
