With the nightly builds of v18 MPEG-2/MPEG-4/XVID files in SD quality are only played in slow motion!
Last working version
The last working version is Kodi 17.6.
Tested on
Android ARM64
Android ARM
Fixed with PR 15056! THX peak3d
https://github.com/xbmc/xbmc/pull/15056
rainman74
Can you be specific with build you are using. Should be able to get the info from Settings>System Information.
Which was the last build where it worked correctly? A
Debug Log will help
I have tested Win 64 KodiSetup-20180617-e14a6f89-master-x64 and no issue there.
Karellen The problem concerns as far as I can tell only the Android build, I have noticed it from the release kodi-20180602-b5181d72-master-arm64-v8a, but can't tell when exactly this occurred.
No technical description / no logs -> no issue.
(2018-06-25, 13:51)peak3d Wrote: [ -> ]No technical description / no logs -> no issue.
Far too many changes -> no sufficient developer testing before committing -> great risk.
Joking aside, what exactly do you need? I don't think you'll find the origin of slow motion in the log, do you?
But I can supply you with anything you need.
Please don't take offense, you're doing a great job!
Slow down is only on Android 5.1.1 (Fire TV), on my Android 7.0 tab there is no slow down!
(2018-06-25, 15:22)rainman74 Wrote: [ -> ] (2018-06-25, 13:51)peak3d Wrote: [ -> ]No technical description / no logs -> no issue.
Debug log with video component logging enabled, pls. just play a few seconds.
All right, I'll do it right tonight...
Your stream is opened using ffmpeg s/w decoder and your device seems not be powerful enough to handle it.
Reason is that your stream doesn't provide width and or height, that is not allowed in current implementation:
https://github.com/peak3d/xbmc/blob/mast...c.cpp#L407
Most probably an issue in your source data.
FernetMenta why is stream not parsed from ffmpeg until ffmpeg has valid SPS before selecting decoder?
My device is a Fire TV 4k box that can play 1080p h.264 streams smoothly even without MediaCodec.
The tested VOB streams are part of regular PAL DVDs (576i), which were copied 1:1 to hard disk.
In Kodi v18 builds at the end of last year they were still running smoothly, but I can't tell exactly from which Kodi build this is no longer the case.
peak3d problem still exists in kodi-20180703-f0dda3a0-master
