I've got an iMac hooked up to an external LCD. When i move my XBMC window on the the LCD, it still fullscreens on the primary display. how do I make it fullscreen on the secondary display
um go into options and when you choose the resolution keep scrolling until you get your 2nd displays res then hit test resolution right underneath it. that should work.
thanks. that worked, except the image doesnt fit on the screen now (the resolution is set to 1280x720, which is correct)...
This should fix you up.
Go To:
Settings > Appearance > Screen > Resolution > Then choose the "fullscreen#2" resolution.
Also,
Settings > Videos > Player > Resolution > "fullscreen #2"
hmm still not working...thanks for your help though.
i closed the app, deleted the XBMC folder in user-->library-->application support, tried the settings again and now it works
nightrain811 Wrote:i closed the app, deleted the XBMC folder in user-->library-->application support, tried the settings again and now it works
That fixes EVERYTHING!
